Hydrapower oil line ??
herk
Hello I blew the Hydrapower oil line on my 1850 ,my ?? is can I replace that line with Hard brake line with several loops in it or dose it have to be hose . Thanks Bryan
I put this on my 1550. Some PO had a tiny line, very crooked, but it worked. I used flare fittings and the radius from my tube bender was just right for the span. Made the bend then adjusted the lengths to match the elbows. A local car repair shop put the flares on with a hand-held hydraulic tool. The leak is from the O-ring which I replaced along with the rear seal at a later time. Been working fine.
