Hydraulic Pump Suction
Norberg
This message is a reply to an archived post by ChrisLSD on January 30, 2009 at 06:54:41.
The original subject was "Hydraulic Pump Suction".
If I remember right, I think the 7120 has the hyd. pumps stacked in tandem. The front pump runs your power-steering and remotes while the back runs your 3-point. If the power-beyond plate was removed and PLUGGED, your fluid is not circulating. The hyd. reservoir IS the 3-point unit. You either need to find another power beyond if you plan on using a loader or a remote-valve w/an end-plate, or an end-plate. The end-plate ports are connected so that the fluid will circulate. The previous owners should have known better.
