hydraulics help please
molson59
Hi folks,
I hope that some of you hydraulics experts may be able to help me out.
Here is the situation, I have an older international B414, with manual steering.
I bought a power steering kit for it.
the power steering unit is made by anandul, it is a complete unit that basically replaces the rod that from the pitman arm on the steering box to the steering connector out at the axle.
this unit has a small lever arm on it that reacts to pressure from the steering box pitman arm, this in turn causes the hydraulic cylinder to move, thus turning the tractor.
I want to plumb this into my existing loader hydraulic controls.
However, these controls are open center type, meaning that the hydraulic fluid flow is constant through the controls and back to the resivoir.
I don't see how I can tee into this for the power steering unit, cause it looks like it would dead end the hydraulics at the power steering unit.
I talked to the people that sold me the unit, they said I need a priority valve tee'd into the supply side of the loader hydraulics. this doesn't make sense to me with this open center controls that I have.
Has anyone had any experience with this situation.
Any suggestions
thanks in advance
mike
A priority valve splits off part of the flow to go to the steering. This partial flow will be constant regardless of what the loader is doing. Downside is your
loader will be slower. I would recommend getting an adjustable flow divider so you can set it to work best with the flow you have.
The priority valve is designed to make sure the PS gets first dibs on pressure and flow. It passes all fluid through it when no
steering input is sensed, and the rest of the tractor hydraulics work as normal. When steering is sensed, the valve diverts flow
to the steering, but only the pressure set by an adjustment. Thus both the tractor hydraulics and steering can coexist. Jim
i do have an adjustable priority valve.
the problem i see is that the PS unit does not have a center open setup, meaning that if there is not steering being sensed, then there is not constant flow thru the power steering unit. I think this unit needs a constant pressure available to it.
That is why i was concerned about the open center hydraulics for the loader.
i have read on this site and another that i need a seperate or piggybacked hydraulic pump to use this PS unit, i assumed it was because i have open center hydraulics on the loader.
am i way off base on this?
And do i Tee the return line from the PS unit into the return line from the loader hydraulics.
thanks
mike
XX3 on installing a priority valve in series between pump and loader valve. You need a
constant delivery of at least 3gpm for the steering siphoned off before the loader.
Your loader will be slower though.---Loren
(quoted from post at 15:21:30 08/14/19) Hi folks,
Any suggestions
thanks in advance
mike
What part of the world are you in, and what is "anandul" power steering?
It doesn't seem like GOOGLE has heard of it.
If you could post the a link to the manufacturer's website so the folks trying to help you could read up on exactly what you have it would be helpful, IMHO.
Mike, welcome to YT! Unless I am way off base I believe the control valve in the steering unit
works a little different than you describe. Generally those assist style power steering systems
utilize an open center style system because they operate with a separate engine driven pump. In
your operating description the flow stops if there is no flow for steering fluid required. More
likely when the sensing valve on the unit does not require fluid flow to adjust steering the flow is
just going through the valve and back to the reservoir. That is where to priority valve comes in to
direct part of the flow to the steering.
MY BAD
the manufacturers name is anadolu, i believe it is Turkish.
i cant find a model #on it.
i bought this from an american site.
i am actually in central british columbia canada.
"XX3 on installing a priority valve in series between pump and loader valve."
i am not sure what you mean with the xx3, is this code for something?
are you saying that you believe i should install the priority valve on the supply side of the loader controls?
confused- mind you i am easily confused.
Hi Bob,
when i google it, most of the references are actually to this site.
if you google it and look at images, you can see a couple of really good examples of what i am talking about.
Hi all,
i really appreciate your help and patience.
From all of your comments, i think i have a better understanding of how this is supposed to work. I hope!
if the power steering unit is open center as was pointed out, then i should be able to install a priority valve(adjustable one) which should, if i understand correctly, split the flow from the pump to the loader controls and to the power steering unit.
having said all that, does that mean that there is always some flow to the PS unit and the loader at the same time.Or only flow to the PS when there is a demand to steer.
As well, there is the question of where to direct the return flow from the PS unit.
i hope i havent muddied the waters too much
thanks again for all your guys input much appreciated
mike
tomorrow i will post some pics of the PS unit and the priority valve. along with a rudimentary drawing of what i am proposing do do.
Have look and please feel free to comment,suggestions or critique.
i am going to attempt to attach a drawing and a couple of pics to clarify my situation.
i said earlier that the priority valve was adjustable, but now i see that it is not
Please have a look and tell me if this will work or make some suggestions as to how i might make it work
thanks again
cheers
mike
From the "YT" archives
See below...Located info in the "YT" archives..
We carry the full line of Anadolu Hydraulic P/S Kit replacement parts including the right hand pitman arm. Our toll free telephone number is (877)847-6195.
I recognised the name as I spent time working in Turkey.....Istanbul
Bob..Norther BC Canada..
thanks bob,
right now i dont need any parts, just advice on how to make this unit work with my existing hydraulics
cheers
mike
hi Bob
it turns out that i may need parts for my PS unit.
i tried calling the phone number that you posted, number no longer in service.
do you know what small setscrew and locknut are for on the unit?
I was turning the setscrew in and out to see if the unit would behave properly. Unfortunetly i turned the screw out too far and it fell out. i need to know if there are other parts inside that i have lost. looks to me like this is some kind of relief setup, and i am thinking that there should be a ball and spring behind the setscrew.
if anyone else knows anything about this, please advise and let me know if i can get any parts that i need.
i tried looking for parts at YT, search results for anadolu come up empty.
cheers
mike
