Hydraulics Quit
wolfman
Low houred Farmtrac 70 (about a 4610 Ford with a
flat deck) the hydraulics just quit. Parked a couple
hours with a 7-ft blade in the up position. Put it in the
shed that eve and it didn't really want to lower the
blade - then it wouldn't lift it. Power Steering works,
but hitch nor remotes will grunt. Some valve
sticking?? Tractor has sat too much.
Hummmm,??. Yanmar plays that card occassionally here ,, I crack lines and bleed for air while activating the levers ,, not saying this is Your problem ,, you could have a sticking valve somewhere ,,If it were mine I would try Lucas tranny slip added to hydraulic s....
