I discovered after dealing numerous with failed battery packs for rechargeable tools that most of the time, there is only one in the pack that is keeping it from recharging. Typically the pack has been run too low,, one of the cells went to near zero charge. Then the charger does not recognize the pack and will not attempt to charge it.
As others have have noted, if you jump that cell with a little charge, it will come back to life.
Now, much to the annoyance of my wife, I always harvest the cells from rechargeable devices. Most use Li-ion cells.
I purchased an inexpensive OPUS BT-C3100 charger to test and keep cells charged. It cost less that 16 packs of AA alkaline cells. I have 2 trail cams that each burn through 8 cells in a little more than 2 weeks.
8 AA cells provide 12 volts. 3 Li-ion cells provide 12volts (nominal). I put 2, 3 cell strings together to last longer. The camera shuts down when voltage drops to 8 volts or 2.6 per cell which is close to the correct minimum for a Li-ion cell
The charger has some nice features.
From the link provided;
*Modes: Charge, Discharge, Test, Quick Test and Refresh
*Output Current up to 1A x 4 channels (selectable 200mA, 300mA, 500mA, 700mA, 1000mA) or 2A x 2 channels
*Backlit digital display showing battery voltage, charge/discharge current, charging time, battery capacity, etc.
*The quick test mode tests the battery impedance
*The charger integrates the minus delta voltage for NiCd or NiMh battery charging termination, and for Li-ion batteries charging to 4.2V with pre-selected current
Li ion charger
