I just never thought about it
My wife and I took my son to college. The engine ran at 2,500 rpms almost the whole time. it took us around 18 hrs round trip. The engine turned over 2,700,000 times. The pistons went up 1,350,000 times and down another 1,350,000 times. Never thought about it before, but I think it's amazing. Over the life of a vehicle the numbers would be unbelieveable.
"The engine turned over 2,700,000 times. The pistons went up 1,350,000 times and down another 1,350,000 times."
Nope. the pistons went up and down 2,700,00o times.
You forgot the exhaust stroke.
Just to be picky.
If you want to be impressed, count how many times you heart beat during that time.
Kenny
I recall reading somewhere once that if an engine used one drop of oil ever revolution, it would consume something like a quart every three miles, or something like that.
You are correct (it would have fired 1/2 as many times per cylinder, but the strokes were there)
If it made 2.7 million revolutions it made 2.7 million ups, and 2.7 million downs.
When they do they usually cause an audible racket if the other pistons continue to stroke I think they are just complaining too much like the kid hired to move small squares sitting under the wagon. Jim
I beg to differ...if the crank starts the rotation when the piston is at tdc and turns 180 degrees then the piston would be at the bottom of the stroke...then the crank turns another 180 degrees to finish one revolution of the crank the piston would be back up to the top....one reolution of crank hence, 2,700,000 revolutions and hence, 1,350,000 down strokes and 1,350,000 up strokes
A General Motors, (EMD) locomotive on Burlington
Northern Santa Fe can go from Chicago to Seattle
and back to Chicago again in 1 week, on a UPS or
U.S. Mail train. At 60 miles per hour the 16V645
engine, (V16, 645 cubic inch per cylinder) is
running at 800 RPM, using 200 gallons of diesel
per hour, at 3200 horsepower!
How fast is the crankshaft turning ?
And a John Deere two popper at 1000 rpm will have nearly same piston speed as 560 running 1800 rpm. Old argument from way back when.
That wouldn,t be hard to figure 1,080 min to 18 hr.
Average heart rate around 80 bpm (not allowing for the occasional mini skirt, short shorts ,or a semi revealing top)is only 86,400 beats.
(quoted from post at 17:28:33 08/28/10) A General Motors, (EMD) locomotive on Burlington
running at [b:404188f99c]800 RPM[/b:404188f99c], using 200 gallons of diesel
[b:404188f99c]How fast is the crankshaft turning [/b:404188f99c]?
