I saw some confusion below regarding if Ignition Coils are Polarity Sensitive and if standard Ignition Points are Polarity Sensitive, so as a public service to my great bunch of fellow YT ers, I will provide an electrical engineers "OPINION" and perspective which will hopefully help out. NOTE THIS IS MY OPINION, OTHERS ARE ENTITLED TO THEIR OWN DIFFERENT OPINIONS (but NOT their own facts lol)
1) IGNITION COIL POLARITY There is indeed a reason why ignition coils have their small + and - terminals labeled as such, if it made no difference why label them at all. The reason is its easier to emit electrons from a HOTTER to a relatively COLDER surface (thermionic emission I believe its called) and that's why in a vacuum tube there's a heater located under the Cathode from which electrons flow up to the Plate.
BUT DONT TAKE MY WORD FOR IT IF YOU READ THE ARTICLES BELOW THEY EXPLAIN IT IN GREATER DETAIL
http://www.chicagolandmgclub.com/techtips/general/574.html
http://mgaguru.com/mgtech/ignition/ig104.htm
2) IGNITION POINTS POLARITY
In like 55 years of buying hundreds of sets of ignition points (I was a used tractor dealer and farmer) when I went to
a tractor dealer or NAPA etc to buy a set I WAS NEVER ASKED IF IT WAS A POS OR NEG GROUNDED TRACTOR.
In like 55 years of buying hundreds of sets of ignition points I NEVER SAW ON THE BOX FOR POS OR NEG GROUND
THE REASON BEING """""IN MY OPINION""""" IGNITION POINTS ARE NOTTTTTTTTTTTTTTTT POLARITY SENSITIVE. They work the same
and as well regardless if on a POS or NEG ground tractor (In my opinion that is)
3) IGNITION POINTS PITTING AND CRATERING
It was posted below there existed pictures evidencing how "points polarity" makes a difference HOWEVER the
differences is NOT due to + or - Polarity, ITS DUE TO TOO MUCH OR TOO LITTLE CAPACITANCE
SEE THE PICTURE I POSTED
4) YES Voltage Regulators ARE POLARITY SENSITIVE and the coatings and surfaces on their relay contacts makes a difference. I have seen them labeled for POS ground and I have seen them labeled for NEG ground.
I sure hope this helps and clears up the confusion. If the authors of the literature above are wrong GO TAKE IT UP WITH THEM AND FLAME ON THEM AND TELL THEM THEYYYYYYYYYYYY ARE WRONG NOT ME LOL
If others have a different "opinion" then mine or the authors above, THATS THEIR BY GOLLY RIGHT to which they are entitled and I'm NOT here to stop them even if I, an electrical engineer and past tractor dealer and farmer, disagree IVE BEEN WRONG BEFORE AND WILL BE AGAIN .............I would appreciate an in depth precise technical explanation, however if anyone thinks the above is wrong WHICH IT MAY WELL BE ?????????? But I can swear I NEVER was asked or bought points for POS or NEG ground tractors But I haven't bought all of them either lol so sure there could be a difference grrrrrrrrrrrrrrrrrr
Best wishes and God Bless and keep all here
John T BSEE, JD Retired Electrical Engineer
