IH 2001 loader on 4020 JD
miangus
I have acquired what I believe is a IH 2001 loader from a IH utility. I would like to install this on a 4020 JD. I will have to fabricate the mounting brackets and modify the loader frame. . I have some metal working skills, cut/weld etc. Has anyone done this? Pictures of brackets would be helpful. Thanks in advance.
(quoted from post at 15:39:22 03/23/20) I have acquired what I believe is a IH 2001 loader from a IH utility. I would like to install this on a 4020 JD. I will have to fabricate the mounting brackets and modify the loader frame. . I have some metal working skills, cut/weld etc. Has anyone done this? Pictures of brackets would be helpful. Thanks in advance.
You should be able to do it but you need to understand that that's a lot of tractor for that loader. I have a 2001 and man you have to be careful with it. Mine is mounted on a 70HP IH tractor and it's really too much tractor for the loader. Be safe!
Rick
That's not a very good loader for a 4020, get a 148 JD, or something heavier, or a Westendorf, WL42! Sorry but that's my opinion!
