JIM56
I have a 72 IH 574 when you put the PTO in gear and as the trans oil gets warm it leaks oil from where the rod/shaft goes into the housing. Does anyone know if there is and external seal there or is the seal internal? I am try to find out before I start removing things.
Hello there!
Just for clarification what style are you talking about?
Early 574's had dual 540/1000 PTO in the rear while later ones had only 540 in the back and a side-mount 1000.
Please tell us which style you have so we can better help you.
It's probably like anything else.... if you don't see a removable seal where the rod enters the case, then its probably a major job.
I have a Ford 9700 with a leak similar to yours. Not a drip , just damp. It's gonna have to get a helluva lot worse before I do an under-cab split.
Is it leaking around the PTO at the rear of the tractor? Or around the PTO spool valve rod in the MCV housing?
Check that the trans/diff housing breather that looks like a mushroom under the seat is not clogged and over pressurizing the hydraulic reservoir in the trans/diff case.
If its leaking around the spool,there is a oring in the retaining nut on the spool. Linkage has to be removed then remove the nut on the spool. They collect a lot of dirt there and that usually is the reason for the oring failure.
Around the PTO spool valve
Thanks will check the breather forgot to check that.
Thank you will check that sounds like my problem.
Hello there!
Early 574 it has the 540/1000 PTO in the rear.
