IH TD340 dozer
I live in Southern Wisconsin and I need some parts for a TD340 dozer. The local IH dealedr has been no help. Does anybody else have any ideas. I need seals and bearing for the front idlers Any help would be great.
Joe
Dresser Industries took the crawler business when Case took over IH. I don't know if the 340 is included in that aquisition? There are some parts available from Case for the base tractor under backhoe units if you can determine which tractor is used. I would think a knowledgable CaseIH dealer could direct you and possibly even order parts for you. mEl
A Farmall G @ D,International G @ D and T-TD 340 basic power units are the same. So why wouldn't those Parts still be in the parts books? We are talking early 1960 to 1965 Machines so they are around 45-50 years old. Maybe that is the reason for parts not being available.Have you Googled T-340 IHC Crawler Tractor Parts? Try it and see.IMO JH
you and 100+ Others
seals $120+ ea
and bushings
bet the slides need welded/machined
and idler will need redone/new shaft
