Installing GB loader on JD 4020
LPG
This 4020 has two sets of remote hydraulics and the loader has an open center control valve. My question is: Can I put a pair of JD male coupler ends on the supply and return lines and use one set of the remote hydraulics to make the loader operational? Thank you.
Yes you can attach FEL control valve as you inquired BUT it's much better to attach valve hoses directly to tractor hyd's. This type attachment has been discussed MULTIPLE times with photo's & fitting part #s posted. If GB loader valve is the convertible type that can be changed from OC TO CC I highly recommend to acquire/install a CC conversion plug in FEL control valve
