International 314 plow
SVcummins
Is back to a 314 instead of a 214 had a friend come over help hang the last two bottoms . The front left bottom is still not right I have another shank Im going to try and see what happens if not I think the frog must be bent
I think I see what you're saying. The front bottom looks to be at the wrong angle somehow. Like twisted or something.
I have a 214 I just converted back to fasthitch this year. I finished plowing but its rained so much since then I cant get back into the field.
I cant tell much from the pic. but,I trust you know those are adjustable bottoms?There is a special bolt that holds the frog to the beam. It has a rectangular head with an excentric under. It is the bolt closest to the beam pivot.I'm short on Super Chief bottoms,but may have some extra (spring trip) beams/standardsI have probably 10 (or more) of rigid beams and standards for both sides. I could sell a couple for parts.I have figured out a way to 'straighten' a bent beam. It involves cutting the beam at the bend and bolting it solid to a beam of the oppisite side. Welded with 7018,they work out well.I can telll you more later.Hever heard of a bent frog. Call me. Both of you have my number.I've been running those IH plows(314;642...) for 40 years. I have a few parts(plows)on hand.
I put the arrow in the same position on all bottoms . The special bolt is now replaced with a washer that fits on the bolt and you turn it to the position you want
I may be able to shim it . Ive done that before with the other
shank it worked until I got into some really bad rocks and I
bent the shank almost straight instead of curved
Well it looks like a plow again had to shim the left hand moldboard to get it inline with the other bottoms . Ill have to do some more looking I guess . I know the main frame isnt bent but the Im beginning to think maybe piece that bolts to the main frame is bent or the frog .
