International 684 warning light
Pops kids
Could someone please tell me what the light below means
me what
Oil pressure warning light. If he was mowing in tall brush or near low tree limbs, a branch might have snagged the wire off of the oil pressure switch on the engine.
I have also had the oil pressure switch fail suddenly, it is located on top of oil filter housing with a single wire on it .
IIRC, ground the wire will turn on the light.
Same switch as used on older cars so local auto parts store may have a replacement.
But as other Poster said check the wire first.
<img
src=https://www.yesterdaystractors.com/cvphotos/cvphoto155977.jpg>
From my 684 owners manual. Hope this helps.
Low oil pressure light. I would get a good gauge and put in one of the oil galleys and see what that syas along with the wire check. A live gauge doesn't lie on what is happening. NO need for a lot of line just read it right on the side of the block. IF not sure where to put it just replace the sender with it for a check then switch back for the wire.
