JD 2320 HST question
bumblebee
I have the JD belly mower that goes with this particular model. Some smooth wire from the neighbor ended up on my property and I mowed into it. It wound around the blades and I shut the mower off immediately. After clearing all the wire the blades turn freely but the mower won't run when I pull the switch on. I thought it was a fuse but it doesn't list one for the mower. I checked the fuses anyway and they were all good.
Anyone here that can help me? Thanks in advance.
There will be a wire (maybe a pair) going to the drive clutch. in this will also be one or more safety switches designed to prevent operation in unsafe conditions, such as no operator on the seat, or others. A fuse is a good place to start looking, but the wiring and safety switch/s would be next. a Test light or hand held volt/ohm meter would also be helpful in tracing the failure. JD manuals are on line, and should be able to help diagnose the issue. Jim
