JD #30 Bale Kicker
UP Oliver
Hello.
My kicker is acting up, it kicks a bale and the pan stays out extended. It will not return back to where it belongs for the next bale. I have a manual, made every adjustment. Any help on this is appreciated.
Thanks.
Inside the reservoir there is a plug with a metering jet, which if plugged will do just what you are describing. This is from memory from a long time ago. Be careful not to knock any dirt into the reservoir or you will be doing it a few times. The studs to the access cover like to break off, the steel crystallized from the friction weld.
The return spring inside the cylinder is likely broken. The spring throws the pan back to the home position. The pan will trip once. Then it waves at you.
ive had problems with my 30 thrower, most recent episode, after pulling my hair out, a mechanic told me to take the valve appart, not much in there, as it turns out there was a bolt in there that came un screwed, thru every adjustment I made out the window. put screw back in and tightened it (5/16" or 3/8"bolt) set adjustments again, works
Thank you very much for all the information. When I first realized I had problems I had the kicker off and went over there and turned it on and the pan went out and came back several times until I got over to the Tractor and shut off the PTO. Then it would just stay extended when I turned on the PTO, I did some adjustments, and then it would just stay extended when I used the trip lever. Sounds like either way I got some work to do. But thanks again for the information, at least I know what to look for somewhat.
Have a great weekend everybody.
You keep giving us different scenarios of your problem. You really need to latch the pan home and operate it and tell us what happens. START OVER!
Calm down.
I think if you look at my first posting, and then the last one, it makes perfect sense. The first one explained where things are at right now. The second posting explains what led to the situation I'm at right now. The simple fact is, right now if I want to go bale as soon as one of the bales got kicked the pan would stay extended. I don't think it's complicated.
Thanks.
Yes it is complicated.
If the pan stays extended, the spring inside the cylinder that throws the pan home is broken.
Or the spool valve is not being put back into the home or neutral position.
However, if the pan comes home, but doesn't stay latched that is another problem. The latching mechanism has problems, such as not latching because something is broken or bent or????
Thanks for the reply Roger.
The pan will come back but only after I shut off the PTO. Then it slowly falls back into position. Sometimes I have to give a little shove so it will latch.
You obviously know a heck of a lot more about this than I do, so I'll describe the initial break down as best I can. I was baling and broke a shear bolt on the flywheel. I shut off the kicker to straighten things out back there, and then got back on the tractor and turned on the PTO and went a few feet and realized I forgot to put the kicker back on. When I put the kicker on it kicked even though there was no bale there, and went right back to the latched position. It did this several times until I finally got back over to the tractor and shut off the PTO. I don't know if it latched each time or not when it was repeatedly going through the kicking motion.
I tried it one more time out there in the field and when I put the PTO on the pan just shot out like it was kicking a bale but there was nothing on the pan. And the pan stayed out, extended. I shut off the PTO and went back and shut off the kicker. I put them all on the ground the rest of the day. I got the baler in the pole barn and adjusted as best I could. As of right now I can put the PTO on and the pan stays in the latched position, and then when I use the trip lever it extends out like it's throwing a bale but it stays extended. So that's where I'm at.
Thanks for your help. Much appreciated.
Be very careful so that you or someone helping doesn't get hit by any of the parts accidently, especially if it is tripping by itself. Shut off the baler and tractor. If the flywheel on the baler is not turning, then there is no danger. NO pressure is stored.
With the pan staying out, the spool valve is not returning to the home position (waves at you). Take the detent cap off the end of the valve, it is held on with two screws. Don't loose any of the small parts. Clean it and lube it and the spool. Put it back together.
You may have more than one problem. It should not trip by itself. If it is, the latch needs some attention or parts replaced. There two pieces to the latch mechanism, the trigger and the latch. Either can be worn, bent, broken. Just have to look at it closely.
Since you said it will relatch on occasion, the spring inside the cylinder is not broken as it sends the pan to the latch position. Just sounds like the spool above is sticking sometimes.
Thanks for the new diagnosis statements. Roger
Thanks.
It doesn't trip by itself now, it only did that right after the first break down when I put the PTO going. It only works now when I use the trip lever. I took that cap off already, and did grease it. Still got the same problem. Personally I think there's something wrong with my valve. Right now I'm replacing the front axle seal on my tractor, once I get that done I'll start working on the baler. We got rain coming tomorrow so I got some time
Thanks.
