JD 450 fuel system
hx40905
JD 450 crawler loader my low pressure return fuel lines coming off the top of each injector have no discharge how does this system operate? Thank you!
(quoted from post at 12:31:59 04/09/22) JD 450 crawler loader my low pressure return fuel lines coming off the top of each injector have no discharge how does this system operate? Thank you!
Are you having trouble with the operation of the engine?
If the injectors are in good shape there will be VERY little fuel entering the individual injector "leakoff lines".
Some engines have the return fuel from the injection pump "tee'd" into the injector leakoff line, if that's the case with yours there will be a constant return flow of fuel from the injection pump itself back to the tank.
Injectors that are working correctly have very little return fuel, if the line also has the injection pump top return hooked to one end more fuel will come from the pump
than injectors.
HX welcome to YT! Just as a side comment, I am
thinking you may be more familiar with newer common
rail systems like are used on some pickups. A lot of
those engines flow a lot of return from the injectors
because it is essentially a way to cool the electronic
pulse coils in the injectors. This is a whole different
design, much simpler I would add. However, it is
obvious a lot of beneficial things newer more complex
systems do these type of older systems cannot. May
not even apply to you just a shot in the dark.
