I recently fired up my 1959 630 after sitting idle for a couple of months. It had about a half tank of fuel, and I was using my 5 woods rotary cutter. I was bush hogging flat ground with it for about an hour, when it suddenly started to sputter and lose speed, then died. I pulled the choke and was able to get it re-started. I pushed the choke back in once it started, and it kept running, then I continued mowing.
About 20 minutes later, it started sputtering again, I pulled the choke out quickly and it barely kept enough RPMs to stay running. I crept back to the barn in 1st gear and parked it.
The next day, it started as it always does, and I finished mowing my field without incident.
I did notice that there was a small amount of sediment in the glass fuel bowl.
Our local municipality has asked me to pull their haunted hayride with the ole Deere this year. I want to do it, but am concerned about having problems well into the ride and having a load of upset passengers.
I m still relatively new to these tractors, does anyone have suggestions on what could cause these sporadic fuel problems?
Thank you!
Thank you!
