prairieplow07
I have a JD-630 that is filling the differential with oil from the rockshaft. The tractor has 3-pt. When I use the rear blade and have the
blade in the air, the blade will settle and then jerk back up. The 3-pt does not hold the blade in one steady position. I have a manual and
plan to pull the rockshaft housing and fix whatever is leaking. Does anybody know what I need to look for when I have the housing off? Is
there a bushing or seal? Is the oil passing through the 3-pt? I guess I need a direction.
The tractor put so much rockshaft oil in the differential that oil started running out the brake housing. I drained 5 gallons out of the
differential.
Thanks.
differential.
Thanks.
