JD 920 moco roll removal help
tomstractorsandtoys
I have a Deere 920 moco and tore it down to replace a loose bottom roll bearing. After getting the bearing off I found the plate behind it all broke up and cracked. Ordered a new one as well as top roll bearings as well. Got it apart and the bolts that hold the roll bearing go in behind the side of the machine not just the plate like I thought. The only way I can see is to remove the rolls or aleast the top one then maybe raise the bottom one enough to install the new bolts. I am not sure I can handle getting that roll out as I have no extra help.The problem is on the right end which does make it a little easier to get at. Any ideas? Tom
