Jd h hydraulic question
There is a bracket that attaches to the rear axle on the right side for the H-1 plow. Not sure but it can probably be used on other attachments that have their own mounting brackets.
  • 20170308_134117.pdf
The Duplex Control valve was for use with two-way integral plows that required two cylinders – one for each of the two plows. This allowed the left cylinder to lift and lower the left plow independently of the right cylinder and right plow.
that’s cool thanks for pics I have the two brackets.that Bolt to the axle. I don’t have the Cross member with the chains attached is there a part number. Thanks
