Been working on getting the 55 combine in the field, but fixing one thing always leads to another issue, of course. I finally got some bearings replaced, and the electromagnetic clutch for the header cleaned up and working properly.
The issue I am having is that the 335 header will not engage. I tried the clutch without the chain on, and the sprocket behind the clutch spins. Either the corn head is seized somewhere, or the clutch assembly is weakened to the point it can’t engage that old beast of a header.
When I spin the clutch flywheel by hand, I can get the chains moving on the corn head, but only a little bit at a time. Should I be able to spin the flywheel by hand enough to notice some real action in the corn head, or is there just too much weight to do it by hand? Don’t want to get another hernia.
Wanted to throw this out there on this forum. I have some lockout studs, but I don’t want to use them if it may cause damage because the head inoperable. If it’s a clutch issue, the lockout studs will serve their purpose until I can get in there and figure out the electrical issue. Any input will be appreciated! Thank you!
