JDEMARIS.. CUCV Part
Roy Suomi
John...My M1008 had a problem last week....Starter stayed engaged and cranking till the battery cables were removed.....I contacted Memphis Equipment about a new starter relay next to the ashtray.....77 bucks !!!! I went on Steel Soldiers website and found that a NAPA mower solenoid will work in it's place..Part number , 7-01860-1.....$ 14.95 .....FYI
Sorry not Demaris but just wonder about the current handling ability of that mower solenoid. Just trying to help. Dave
Don't assume that all info from Steel Soldiers is good. It's just like any forum with good and bad input.
I use NAPA electric parts sometimes just because it's convenient. That relay you bought is rated at 12 volts/ 200 amps for intermittent duty, and around 30 amps continuous.
It would not be my first choice but may be OK for what you're using it for. The NAPA 7-01851
is the HD version of the same sort relay.
