Jelled or not?
Im sure my diesel fuel is summer. Im wondering if it may have jelled. Monday temp. About six. Yesterday up to 30. Down to 20 or so last night. Now about 34-35. Think the diesel will flow/the tractor will run?
My F250 was sitting out with the block heater plugged in (HA!). Tuesday morning the truck had at least 8 inches of snow all over the hood where it had drifted. I let the glow plugs go a little longer and it fired tight up. I drove down to check on the well then around the hood. Yesterday after not being plugged in it struggled to run smooth. It finally did. I've had it plugged in since I got back from checking the well again. I normally pour some Ctane booster/injector cleaner in with a fill up and was going to get some winter stuff but didn't. the glow plugs and injectors have less than 10,000 miles on them.
I am in Minnesota. I dont see many problems at all until the high temp doesnt hit 20.
You should be fine, you might have an issue at 6am the night before it was 0 degrees, but if you warmed to 30 will be fine for sure.
Paul
Before I started mine after sitting all winter, I added 5 oz of Howes and 5 gallons of winter blend diesel. Cycled the glow plugs twice and she fired right up at 9 degrees. No problem.
Next year at end of mowing season, I plan to run most the the diesel out of tank, Wait for winter blend before filling it up.
Geo
Summer diesel fuel will start to gel at about 34 degrees.
You will not notice it till about 15 to 20 degrees when it gets so thick it will not flow threw the filter.
If you buy your fuel as you use it you will be buying a winter blend in colder months.
This fuel will work down to about zero degrees.
Anything below zero and you better be adding a additive.
Once the outside temperature gets back in the 35 to 40 range you will never be able to tell if the fuel has gelled in the past.
Want to see what diesel gel looks like.
Put a bottle of kitchen olive oil in the refrigerator.
Another issue with cold fuel temps is increased viscosity. A good clean fuel filter will be ok but if its dirty and partially restricted you might have a flow issue that can give similar symptoms.
This is similar to cold engine oil, but oil filters have a bypass. The bypass allows oil to bypass the filter so the engine still gets proper lube when running. Fuel filters do not bypass though for good reasons but the engine might not get enough fuel though.
Put a additive in it and you should be good. I use Power Service in my bulk tank and have no problems although many on here say its no good. It was minus 15 degrees here this morning and I had two Diesels running today to grind feed and plow snow with no problems. I use No. 2 fuel year round and run 3 small Diesels all year.
(quoted from post at 19:07:13 02/17/21) Put a additive in it and you should be good. I use Power Service in my bulk tank and have no problems although many on here say its no good. It was minus 15 degrees here this morning and I had two Diesels running today to grind feed and plow snow with no problems. I use No. 2 fuel year round and run 3 small Diesels all year.
We defiantly still had non-winter blend being sold down here in North Texas. We treat our fuel in our bulk tanks in the Winter with Power Services, and dont have problems with it. However, some of our guys at work filed their pickups up at stations Northwest of DFW, some in Abilene and Odessa area, all of them had the fuel gel on them two days ago when it was 10 degrees.
(quoted from post at 20:07:13 02/17/21) Put a additive in it and you should be good. I use Power Service in my bulk tank and have no problems although many on here say its no good. It was minus 15 degrees here this morning and I had two Diesels running today to grind feed and plow snow with no problems. I use No. 2 fuel year round and run 3 small Diesels all year.
Do you only have your bulk tank filled in the summer? You don't say where you are but fuel suppliers around here usually start delivering winter blend #2, not straight #2, by some time in November. They don't advertise it specifically, they just do it, since it is needed. If you are getting fuel in the late fall/winter I expect there is a good chance you are getting winter blend #2. We always dose our bulk tank with Power service or Howe's, before all deliveries.
I've never heard of #2 diesel gelling at 20°F. But this is Texas after all, so anything is possible. If in doubt, add some Power Service or Howes additive and fire it up. If it runs for more than 30 minutes you're probably in the clear.
They sell fuel here in CO in the summer that will gel absolutely solid, will not even come out a 1" NPT plug. This will undisputedly happen before "0" and will happen occasionally at 15-20 above. These biodiesel ultra low sulfur summer fuels are absolutely no good much below freezing temperatures with out additive. REMEMBER, powerservice has 2 options, one is additive, one is antigel additive. If you are buying the additive without making CERTAIN it is antigel additive, you can pour the tank full and likely not correct the issue. REmember when winter fuel first comes online in the fall, it is not full strength winter fuel because the supplier had summer fuel thatmixed with treated fuel, the transport had summer fuel carryover blending with treated fuel, then the station had a tank of carryover summer fuel mixed with a half a$$ winter treatment dilluted along the way, so the first 1 or 2 fillups of "treated" fuel are not going to be absolute. not to mention your machine's tank. I put antigel in along with a moisture remover in my tank in the late summer in orer to prepare for winter, but my diesels are expected to run and work in temps own to -35 occasianally throughout winter.
Understand that the problem is in your filters. It is a function of not just temperature but also rate of fuel consumption. I agree with the 20 degree threshold. I had trucks towed in a few times when the drivers were lax with adding the fuel treatment. It was never down to 15 when it happened, but the noticeable number of trucks dead beside the highway would occur at around fifteen. The fuel will start to jell in the tank and the filter will hold just so much before it obstructs flow just like with any other solid contaminate. Once fuel starts to jell in the tank you have only so many gallons available to burn before it shuts down. This will be affected of course by hot fuel returning to the tank, but unless the tuck is burning a good amount of fuel the returning fuel will be just warm.
Actually they make several products. The two most commonly available here in Michigan are "Diesel Fuel Supplement +Cetane Boost" and "Diesel 911". Both will prevent gelling. Diesel 911 is specifically intended for use when gelling has ALREADY OCCURRED. PS recommends the use of Diesel Fuel Supplement +Cetane Boost, not 911, to PREVENT gelling.
I put a quart of PS Diesel Fuel Supplement +Cetane Boost in my oil furnace's outdoor tank each fall. Since I started doing that, I've never had a problem with gelled fuel.
After 50+ years of running diesel cars, trucks, and tractors in a climate that regularly sees sub-zero low temps I can say with confidence that the only way to positively avoid fuel jelling issues is a fall filter change and a 50-50 mix of #2 and #1 (Kerosene). I have, and still do use, various snake oil treatments with varying success but I know for certain that the 50-50 will work at -40.
(quoted from post at 11:00:55 02/17/21) Im sure my diesel fuel is summer. Im wondering if it may have jelled. Monday temp. About six. Yesterday up to 30. Down to 20 or so last night. Now about 34-35. Think the diesel will flow/the tractor will run?
If you haven't run the tractor in the extreme cold to suck the filter full of wax, it will be just fine.
You guys and fuel scares sound like politicians talking.
Unless they are down south with this sudden cold it should be alright just as it is out of the tank. I ran over the road with no problems and would shut the engine off at night in the winter. Even below zero and would start and run fine in the morning. No place to plug in block heaters in truckstop parking lots I ever saw.
Most inhabitants of the northern part of North America don't understand that diesel fuel in the southern part of USA isn't the same configuration as it's northern counterpart.
Many yrs back I had the fuel crossover line between the saddle tanks gel in Kansas on the tractor truck I was driving hauling new JD tractors that were loaded in Waterloo,Ia. This truck had southern fuel in it with fuel conditioner BUT evidently not enough conditioner for the cold temp.
I remember having to put fuel in RH tank in Gutherie,Ok to get truck back to Texas
When driving this truck to Iowa in the Winter engine was only shut down to check engine oil then restarted. One driver stopped engine for layover & it took a mechanic 4 or 5 hrs to get engine started running again.
(quoted from post at 03:59:48 02/19/21) You guys and fuel scares sound like politicians talking.
Caterpillar guy, try reading my post again. Sure a conscientious owner operator can drive for years without a problem, but in real life for the most part drivers are employees, some good some bad and you have to work around the shortcomings of the mediocre. Over 25 years of operating my business in the north country, I had probably ten instances where I had to go out to recover or send a tow truck to bring it in to my place or another shop. The fuel was always blended for the north country, and the driver had skipped adding the Power Service too many times. It is just life.
