JOHN DEER SPREADER
I HAVE A VINTAGE JOHN DEER MANURE SPREADER STEEL WHEEL HORSE OR TRACTOR DRAWN SEEN ONE ON THIS SIGHT ,LOOKS THE SAME RED WOOD GREEN STEEL WITH HORSE DRAWN SET UP WHAT MODEL OR YEAR WOOD IT BE AND DOES IT HAVE ANY VALUE THANKS
You need to give us a bit more information to help ID which model spreader you have. Does it have a single beater on the rear axle or three beaters including an auger-like wide spread? Is the floor solid with a chain-type conveyor (flat chain links on either side with angle iron cross pieces) or is the floor made of cross slats linked together by metal hinges on either side of the spreader. If a single beater and moving slatted floor it is most likely a Model A or Model B. If three beaters and the chain type conveyor apron it is most likely a Model E.
