John Deere 830 , 2 cyl.
Tim W.
What thread is the bronze drain cap on the
bottom left hand side of the 830 radiator ??
Right or Left hand ??
Right hand thread.
Originally, there was a hex-headed steel pipe plug in there with a LONG head.
If you are seeing a "brass cap", someone must have installed a pipe nipple and capped it off at the bottom with a brass pipe cap.
I'm curious... WHY would you even consider it could be LH thread?
Why take a chance and break something by forcing it in the wrong direction in an attempt to remove it. When I observed the 1st 3 threads
from the lower unit down, it almost looks like it's Left handed. Also,some threads ( Int/ext)
located on the bottom of some radiators are
left handed. Having managed a Machine Shop for
a lot of years, I've seen many unordinary things adopted/cobbed together. Thank-You for your Help.
