John Deere No.8 mower
super99
I have a JD #8 sickle mower for sale. I have mounting brackets for a 2 cylinder tractor, model 70 and the guy looking at it has a JD 3020. Will the brackets that I have work on his 3020??
With a little modification yes
Mounting brackets for 2 cyl tractor will not easily fit a 3020. If I were intending to mount #8 mower on 3020 I'd make a tube that fit mower mounting clamps that had a Cat ll pin on each end. One would need to lengthen the driveshaft.
Shown below is JD engineers sickle mower mounting brackets for a New Generation tractor such as a 3020
This post was edited by Tx Jim on 06/03/2021 at 05:00 am.
[b:654c4848f0][i:654c4848f0]< make a tube that fit mower mounting clamps that had a Cat ll pin on each end >[/i:654c4848f0][/b:654c4848f0]
Agree.
That's what I did to my no. 5 and made a drive shaft extension. If you go this route you will need to work out a way to block the three point control so you don't lift it by mistake or you will mangle your mower drive.
