I have a 1956 John Deere Ar Styled that has had issues staying running. It would run ok for a while then slowly get worse and worse until it would stall. I could get it to run but then for shorter and shorter periods, I thought it was a fuel issue as the cab rebuild i did seemed not perfect, I purchased a new fully built Carb. from Martin tractor. It worked ok then i took it for a small drive and started having the same issue. I dont think its dirty fuel i drained the tank and put fresh in and the glass sediment bowl seems clean and screen in the carb looks clean as well. It will fire and run a few seconds then die like there is no fuel or its choking itself. If i move the Choke in and out i can somtimes keep it running a while but it dies. As it dies the exaust sorta puffs black smoke. Any help or thoughts would be welcome, I have unhooked the governor and opened the air intake to see if those were causing my issue but it still acts the same. One cylinder seems wet the other does not but not a excessive amount on the wet side. Spark seems fine.
