Kewanee 500 Elevator manual
JensenFarmer
For several years, I have been searching EBAY and other locations in an effort to obtain a Kewanee 500 Elevator manual. A scanned copy (PDF) anything works... does not have to be an original. Posting here as a call to the masses to see if one is available out in cyberspace! Thanks in advance.
Right now, just general service questions, chain tension, ECT.
Tighten the chain enough that it does not follow around the sprockets on the bottom. Grease all the zerks, oil the chains, make sure the belt is tight. Brush some used oil on the cable
wrap of the lift cable. Not much other service to do. Periodically pour some used oil both sides of the conveyor chain. If the adjustment of the conveyor chain is at it's end you will
have to remove a link from each side. If you pull it much on the road get decent tires and keep them aired up. Nothing more bothersome then planning to use it at the other place and blow
a tire during transport. Screws up the whole day.
Thanks Kerwin... that would be great. Can you suggest the best way to connect as opposed to me posting my email address here? I tried to send you a private IM within this site... did not appear to work. TC
Just finished shorting and installing new bearings at the roller end on this elevator as I am converting it for a wood elevator. Looks like you have an electric motor on it, do mind sharing the specs of the motor? Thank you
