I’m curious as to what causes a problem I am having with a Massey Ferguson 135 gas tractor. I’ve also had the same problem with a Farmall Cub and a Farmall 140 tractor ......all of which are key start systems. When starting the tractor and turning over the starter with the key switch, The switch is not letting fire/battery power to the coil. When the key/starter is released, it allows fire to the coil then. Basically when the key is on the “on” position you have power to the coil but in the momentary start position it doesn’t have power.
Is this a simple wiring issue I have made a mistake at, or does this mean the key switch is bad?
