Wrangler1973
I'm dumbfounded. I did some painting on the lights for my DC and after getting some gaskets for them and reinstalling the lights on the mounts only one will light up. Both headlights will work but only if mounted on the right pedestal. I did nothing different with the wiring of the lights or the wiring from the light switch on the tractor. The rear light will not work at all, even after getting a new flood bulb, where as before the red light would come on now that won't light up either. I've tried using a jumper wire from the right headlight to the left and still nothing happens to light it up. I've also used a longer wire and bolted the light from the right to the left and it will not light up. Is there a grounding issue that I'm missing? I'm not very mechanically inclined when it comes to some of these issues so forgive me for my lack of intellect in that regard.
I'm hoping to resolve this issue so I can get to the major issue of why the tractor won't start. It turns over like no tomorrow but doesn't seem to have any spark to ignite. I had the carburetor rebuilt a couple years ago and after installing it I can't seem to get the tractor to start.
As always thank you in advance for any and all suggestions and advice.
Gene
Gene
