Lights not working
46brown
I own a 2007 Branson 2910i. A while back, the headlights, blinkers, tail lights, and horn stopped working consistently and would only work intermittently. Now they don't work at all (the brake lights and white reverse lights work fine). The 2 fuses that are connected to the 4 non-working functions looked fine, but I replaced them anyway. Didn't help. I checked the fuse box and it looked clean, no rust or corrosion, and the wiring connections looked good. Wiring harnesses all looked OK. I ordered a new switch that controls the 4 non-working functions from my TYM/Branson dealership. Didn't help. If anyone could give me any ideas about what else I should be looking for, it would greatly appreciated. Thanks!
I
You need to be able to test to find where the power stops. This is not something you can see just looking at it. If you do not have a test light or voltmeter, get one, both would be good to have. You can have both from Harbor Freight for less than $30, $4.99 for the test light and $19.99 for the basic volt/ohm meter, than you have something to work with. just changing parts can get much more expensive.
And Welcome to the forums.
