My loader has suddenly stopped going down freely. Originally lowering the bucket was tricky because the valve opened very quickly allowing the bucket to drop too fast. It took a sensitive touch operating the lever. Now the loader drops very slowly, about 2 inches/second max. It doesn't mater if the engine is running or not, the thing just drifts down. Oddly the engine does seam to change pitch just slightly when opening the valve to lower the bucket. (could be my imagination) It lifts fine and the bucket rotates as before. This started after several hours of scooping dirt from root infested soil. I did my best to loosen things up with a rototiller first but it was just about all the little tractor could handle. Trying to level the soil with the bucket by backing up with the bucket lowered did not work because the loader just lifted up over the soil. Did I cause damage by putting back pressure on the control valve?
Reading previous posts on similar topics there is some discussion of quick connect fitting failing but all my connectors are old school. The oil is new and the pump seams to produce a lot of pressure. I once lifted with chains a 12' x 18" diameter tree section! Had to put extra air in the front tires for that one.
It is a 1958 Ford 851 with what looks to be a dealer add-on or a factory installed loader, if that was an option. I say this because it has what looks like original Ford safety stickers on the framing. The tin manufacturer placard on the loader frame reads:
Mid Western Industries Inc.
Wichita Kansas
Model 102 A
SN 19795
I can not find any numbers on the control valve so I am including a picture. I really do not want to tear into the control valve without knowing if replacement parts are available. An exploded view diagram would also be nice.
Wichita Kansas
Model 102 A
SN 19795
