Loader on 1855
tom upton
Putting loader off the 2-70 onto the 1855 and wondering where the best /easy place is to tap into the hydraulics to feed the loader control valve? Not a fan of using the remotes. Anyone with a closed center tractor that has done this I would sure appreciate if you could share where your pulled pressure from. Thanks
I did a Google search for Oliver 1855 power beyond Tom. It came up with some YouTube videos showing the whole process. Might be quicker than waiting for somebody here to walk you through it.
Something that I'll probably never know the answer to was when I bought the Du-al loader that's on my 1600. They had it for sale because they'd bought an 1855 with a loader. That thing was so slow it was nuts. They asked me if I knew what was wrong with it. I didn't spend much time on it, but something definitely wasn't right on that one. I hope you have better luck.
O/K thanks. I will check it out.
The 2-70 had open center hydraulics, didn't it? If so, you will need a closed center loader control valve or a closed center conversion plug for the valve on the loader now, if it is a convertible one.
Generally, on a closed center system you can just tee into a pressure supply line, no power beyond issues. I am not familiar with the supply to the valve for the remote couplers on and Oliver however on a number of JDs that supply line is tee'd into to supply pressure to a loader valve. The return may go to the filter housing or other places based on the tractor.
It looks like the video of the guy hooking up hydraulics for the blower on a seeder shows you the point to tee in for supply and the return point in the housing. You don't need a valve or anything to reduce flow or pressure to your loader. We use quick couplers at the tractor connection points for our loader supply and return lines so we can unhook them without draining anything, if the loader needs to come off.
I’m curious why you don’t like using the remotes. I love using them on my cx100 Case. My broken right shoulder surgery left me unable to raise my right arm for joystick. The levers on this tractor are in the perfect spot. Even before shoulder problem I don’t know how a joystick could have been better.
I'm not Tom but I can say why I don't like using the remotes for a loader. The loader stays on the tractor and often I need to hook up to a remote cylinder(s). I want both live to operate without using a diverter valve. Also, we are converting old leaking loader valves to 3-spool valves on the tractors we use the bale grab, grapple, and other loader mounted hydraulic attachments on, rather than long hoses back to a remote.
My 2 cents would be to use a PTO pump, more volume at lower RPM and less risk of contamination of the oil in the tractor, have PTO pumps on both of my 1655s, one farmhand and one great bend.
That comes with the same problem you have with using the tractor remotes, what if you want to use the PTO while the loader is on?
Not that a PTO pump is bad, but it’s unnecessary in most applications. Only way I could see it being helpful is if the tractor hydraulics doesn’t have enough GPM to operate the loader efficiently.
Left underneath the seat hole goes into the reservoir. I'll have to get a picture for you.
1855 and my 2-110 both.
GG Wes
In addition to what has already been mentioned, it is likely the loader would need its own reservoir if a PTO pump (or additional dedicated front pump). Unless the loader originally had a front pump and used the loader frame as a reservoir, the newer loaders that use the internal tractor hydraulics also use the reservoir for the internal hydraulics.
We have always replaced the T where the hydraulic line that comes up form the pump area provides pressure for the 3 point system and then goes into a line that wraps around the back to the hydraulic spools. The T gets replace with a 4 way T that allows you to hook a hydraulic coupler to.
The return is a 1/2 pipe plug under the seat on the left side of the hydraulic housing. We installed a coupler with a short piece of 1/2 pipe. Be repaired to swap out the plug for the coupler since all your oil will drain out. Hope this helps. We used the power beyond to handle multiple valve banks for a potato harvestor or sprayer.
GG Wes
Thanks. I got it fiured out by watching a you tube video as per rrlunds suggestion. There are 2 locations to get pressure from. One like MikeO has said and the other is the top of the end plate on the remote valve bank, however its only 1/4 inch NPT so I am going with the way MikeO describes. It doesnt look too bad to get at.
