Looking for some suggestions
300guy
I have 7 food plots I have to plant for the CRP contract. I have been using milo and the past 2 years it has been taken over with fox tail. This year I had it plowed and then I killed everything that grew after plowing. Yet the fox tail came back so bad it is hard to find the milo. I will usw treated seed next year and use a pre-emergence. I want to use my ATV with a 7 foot boom I made with nozzles 20 inches apart and 20 inches above the ground. My question is does anyone have an idea how I could mark the spray path so I don't overlap too much which will kill the milo and everything? The boom is made out of 1 inch square tubing and is bolted onto the trailer hitch of the ATV.
Can you see wheel tracks in the soil or crop/grass? If so then make a marker pole on the front of ATV to help you sight along the last wheel tracks.
How big are the plots.
Orange flags at each end to line up on.
GPS on your phone.
I have a cheap gps unit that has a receiver and a screen that is good enough for spraying. Runs of 12 volt. Around $400.
