ls starting isssue
roostertale1
I have a 2017 ls xg3037 , it has been flawless since new. Recent issue i am having is when taking the key to the glow plug position i don't get glow plug indicator lamp or fuel lift pump operation. It can set for a bit with the key on it will start working, the glow plug lamp will come on and the lift pump will start clicking and starts and will run all day. I am leaning on it being a relay but am not sure where to start looking, any thoughts
Fair warning, most of the advice you are going to receive will be the "I told you so" nature, because you bought a Chinese tractor with no dealer support, OR recommendations to junk it and buy a Deere or Kubota.
If you suspect it's a relay, look for relays. Without being able to call an experienced mechanic who is familiar with those tractors, you either have to find yourself a wiring diagram somewhere, or start crawling all over the tractor and poking your head into every crack and crevice.
I will add to Barnyard's post that this forum is focused on tractors that are about 40+ years old. There may
be some advice, but don't expect a crisp answer to an intermittent electrical issue with a new (to us) tractor.
Jim
