Lucas cav issue
mjbrown
Went to look at a Ford 4500 backhoe that has been sitting a while. When the owner started it it was a full throttle start! He slowed it down with the fuel cut off. It then seemed to run ok and he pulled it out of the barn and shut it off. It then would not restart. He said it just started doing this. At home I did some research and I think it is a sticky metering valve caused by varnish from sitting. Has anyone else had this and if so a possible remedy?
Thanks.
Does the Ford fuel system return a lot of diesel,somehow i would guess it got hot, and is old,and the additive package couldn't stop the varnish from forming!
Pump MIGHT work again with fresh fuel, if not it may need torn down for a complete cleaning. Any water in fuel, or bio fuel use will cause valve and plungers to stick. I usually see two or three pumps at least each month like that in for repair..
I may suggest that to him. I went to look at it to possibly buy it. He was apologetic about it and said he would have to get it running right either way.
