I"m guessing that it has the same general arrangement as the M-M 335. My 335 book shows the reservoir and filter cannister assembly under the seat. Capacity 6 qts. with power steering, 5 1/2 qts. without P/S (the capacity will be correspondingly more, of course, if a loader and/or other cylinders are in the circuit. Instructions: Clean thoroughly around plate before removing plate to check fluid. Make sure lift arms are all the way down and any other cylinders (loader, etc) supplied by the tractor hydraulics are retracted. Fill with automatic transmission fluid Type A (or current equivalent) to within 1/2 inch of the top of the reservoir. Change fluid and filter cartridge every 1000 hrs. Clean cannister and screen thoroughly before installing new cartridge. Reservoir drain plug is on the right side of the reservoir, near the lower rear corner. If your 445 isn"t exactly the same, I hope this at least gets you in the ballpark. Good luck.
thanks for the help Im going to change the filter and fluid I live in the midwest having trouble finding anyone that handles parts for these tractors
