marvel Scheibler H carb
Larry D.
This is a continuation of earler post, Just got back to it, JD H won't Run unless CHOKE pulled out over half Way, exactly where is the Idle jet in this carb. I don't want to do a complete rebuild if Poss. it sat with the Carb bowl full of gas for a Couple of Mos. I normally drain, help Please! Larry KF4LKU
If you don't want to do it the RIGHT way and tear it all the way down, first try this.
Get a can of Berryman's spray carb cleaner (or other good stuff that causes cancer in Cali) with one of the thin "spaghetti" spray tubes. Remove the idle and load needles and insert the tip of the spray tub WAY down into each hole and give 'er a few blasts, then repeat a couple of times. This MAY just blow enough crud out of the way so the old girl will run better for a while!
