Massey Ferguson
my uncle just dropped his 231 Massey by for me to use instead of it just sitting on his 1/4 acre lot in Atlanta wondering what the HP rating on it is. Anyone here have the answer?
Per external_link
General tractor information:
Manufacturer: Massey Ferguson
Model: 231
Type: Farm/Agricultural tractor
Years produced: 1989 - 1999
Total built:
Factory:
Original price: $13,000 (1999)
Tractor power:
Engine: 38 hp [28.3 kW]
PTO (rated): 34 hp [25.4 kW]
Engine:
Manufacturer: Perkins
Fuel: diesel
Cylinders: 3
Bore/Stroke:
Displacement: 152 ci [2.5 L]
Compression:
Rated RPMs:
Cooling:
Torque:
Firing order:
Transmission:
Type:
Forward: 6
Reverse: 2
Mechanical:
Chassis:
Steering:
Brakes:
Capacity:
Fuel: 12.7 gal [48 L]
Coolant: 11.2 qts [10.6 L]
3-Point Hitch:
Rear Hitch Category: I
Rear lift:
Power Take-off (PTO):
Rear PTO: live
Rear speed (RPM): 540
Hydraulics:
Type: open
Capacity: 9.2 gal [34 L]
Total flow:
Outlet flow:
Pressure:
Outlets:
Tires:
Ag front: 6.00-16
Ag rear: 13.6-28
Dimensions:
Weight: 4,065 lbs [1843 kg]
Wheelbase:
Length:
Width:
Height:
Ground clearance:
Electrical:
Ground:
231 Serial Numbers:
1989: P17001
1990: Q01001
1991: S01001
1992: A01001
1993: B01001
1994: C01001
1995: D01001
1996: E01001
1997: F01001
1998: G01001
1999: H01001
Hope this helps,
Aaron
