Math to think about
jon f mn
Driving in far north today which means no radio, internet, cel service and streaming radio most of the time. So I had some time to ponder. At 60mph his truck turns 1300 rpms, meaning 1300 rpms/mile. Multiplied by just under 414,000 miles that means this engine has turned over 500,000 revolutions. Taking into account that we do a lot of idling and city driving that total could easy get to a billion revolutions. Take it to the next step and each piston, valve, and lifter has gone up or down 2 billion times +- already. This truck will likely go past a million miles making those number quite something, especially when you take into account that those parts are running metal on metal with just a thin layer of lube. Of course I could be wrong on those numbers.
So how many revolutions do you think your old tractor has? If it has a mechanical tach you could figure it. My 1030 shows about 5,000 hours and with a pto speed of 1800, that would mean half a billion revolutions. Assuming the hours are correct. No wonder they need work every day. Lol
Anything heavy duty or used at or above rated capacity will need worked on maintenance a lot more than say the ol lady’s sedan
Some of the car write ups used to include "piston travel per mile" numbers. It didn't seem to make a bit of difference in the life expectancy of engines. Some of the high revving little Toyotas got three times as many miles before self destructing vs the big slow turning US models. You don't see those numbers reported anymore and probably for good reason. I should add that some engine designs self destruct long before others. The Chrysler 225 slant six (leaning tower of power) vs the Chevrolet Vega come to mind.
I use to run an industrial 15 liter on a PPO ( peak power overload) test and stuff did wear alot faster!
Well Jon, that is a high reving truck, LOL. what does it have? My International with a big Cat turned 1200 at 62MPH.
Dealership I worked at ran an old (even back then) F model Mack. In the bottom of the tachometer was an odometer like read out, 6 digits long. Underneath that it said "number of crankshaft revolutions X 100,000. Not sure I needed to know that
I only had to read it the third time to figure 3 zeros got left off. Easy enough to happen.
The funny is you titled it math to think about.......
Paul
Yep, easier to figure in your head or on a slide rule if ya drop the zeros, but ya gotta add 'em before yer done! Done that a couple of times back in the slide rule days. Learned to always write down 1st results, set it aside for a while, figure it again, write it down and then figure it at least once more.
Once upon a time, I used an eye dropper and my power scale for handloading to figure how many drops of oil in a gallon of oil. Then if an engine burned one drop of oil every revolution how much oil would it burn at a given rpm in ten hours. It was in the gallons.
1,000 to 1,500 crankshaft revolutions per mile could be in the ballpark for a odometer. 100,000 crankshaft revolutions per digit would be more appropriate for an hour meter.
Pete: There are 20 drops of water in a mililitre, so 20,000 drops in a litre. A US gallon is 3.78 litres so that makes 75,600 water drops in a US gallon. Oil not sure, an oil drop's volume might depend on the viscosity of the oil. Not so for water, there is no 10w30 or straight 40 weight water I don't think. Meanwhile, my dad's name was Pete, so was my son's name and one grandkid. A name that is disappearing and if it did show up now with a young fella, it would likely be Peter, not Pete.
