Mccormick 33 loader seals
mschwartz
Has anyone found kits to rebuild the lift cylinders lately? Looks like a 1 3/8 rod inside a 2 3/8 tube. Big cup type seals, not orings like more modern cylinders I have worked on. Nothing looks amiss but the the cups are so hard I can barely flex them with my hands. Loader would not lift at all, not leaking onto ground but were bypass internally I think. Loader was never very strong but would always work slowly before. Today was the first time I had tried to start and move the SMTA for a couple of years. I suspect the local dealer will laugh at me but I will try calling them tomorrow. Thanks, Mike
Just about any cup or seal can be found at online seal supplies. Be sure it is a seal supply, not a hyd repair shop.
There are so many seals, unless you have knowledge of what to look for, it is best to call, make arrangements to mail the old seals, along with the best measurements you can, the application and approx system pressure.
When taking a cylinder apart, it is almost always possible to see what failed.
Typically a blown seal will still lift, but will come back down when the valve is released.
Sounds more like a pressure problem, a bad relief valve or bad pump.
I thought it was a pump problem but the three point lifts the backblade just fine. Switched the hoses for the bucket and the lift cylinders between hydraulic spools and the bucket cylinder worked on both valves. Never really had a problem with the SMTA hydraulics before, must be a pressure relief valve built into the hydraulic reservoir?
You say the bucket cylinders worked on both valves. Are we to assume the lift cylinders did not work when swapped to, and operated with, the bucket cylinder valve? If that is the case, it definitely points to the problem being in the lift cylinders, to me.
(quoted from post at 20:30:41 11/17/20) I thought it was a pump problem but the three point lifts the backblade just fine. Switched the hoses for the bucket and the lift cylinders between hydraulic spools and the bucket cylinder worked on both valves. Never really had a problem with the SMTA hydraulics before, must be a pressure relief valve built into the hydraulic reservoir?
There is, but depending on how you have it plumbed you could be bypassing it.
You would hear the relief valve bypassing, and the tractor engine would grunt a little.
Another possibility is a collapsed hydraulic hose, or a bad quick connector.
Correct, sorry I did not make that more clear. When I swapped hoses around bucket cylinder works on both valves and the lift cylinders did not work on
either valve. Thanks, Mike
I will have to study the plumbing more closely, loader never really worked all that well. Tractor was not running for decades when I got it so I had to
replace several hoses but maybe there is something suspect with how it is plumbed? Really only kept the loader because it was original to the tractor.
I would like to get it functional if possible, thanks, Mike
(quoted from post at 11:33:27 11/18/20) I will have to study the plumbing more closely, loader never really worked all that well. Tractor was not running for decades when I got it so I had to
It would seem if the bucket worked on both valves, but the loader lift cylinders did not work when connected to either of the valves, you need to look at the hoses between the valve and lift cylinders and the lift cylinders themselves. I would suspect the lift cylinder piston cup seals are not holding, regardless of how they look. Repack the cylinders completely when you do it to lessen the risk of an external leak following an internal repair. Just my thoughts.
