Engine is AD3 152 Perkins 3 cylinder diesel.
Trying to diagnose very strange air pressure in cooling system. Just replaced head gasket and experienced air pressure in radiator. Performed a cooling system combustion test with leak detector fluid with no indication. Did successful pressure test and vacuum test on the cooling system with no indication of any leaks. Removed fan belt to disable water pump. Plugged overflow tube and attached exam glove to radiator neck and ran cold engine for 15 to 30 seconds. Still have obvious air pressure.
Why no indication of exhaust gas?
Why no leaks on my vacuum or pressure test? Other than combustion, what other source of pressure could I suspect?
Thanks for reading.
Thanks for reading.
