MF 135 Gauges
swaddell
Recently purchased a Massey 135 Diesel (1964 model?). None of the gauges work and after inspection, it looks like both wires going to each gauge has been cut. Why would this have been done. Looking suggestions and options if we should replace all gauges or can wiring only be replaced.
Welcome to the forums.
The wires you are looking at may be for gauge back lighting.
A diesel MF 135 should have the following mechanical gauges: oil, temperature, and tachometer. The ammeter and fuel gauges were the only electrical ones. The ammeter is direct wired and the fuel gauge is supposed to be turned on and off by an oil pressure switch mount to a tee in the oil line at the back of the oil pressure gauge.
Below is a link to a MF 135 Operator's manual. the wiring diagrams for both gas and diesel are in it.
Hello swadell, welcome to YT! If you are not familiar with tractor/automotive instrumentation what Jim means when he says “mechanical” in the case of the oil pressure gauge a tube connects the gauge to an external oil pressure tap on the engine. The gauge reads the pressure. The temperature gauge reads the engine temperature via a capillary tube and bulb that has captured fluid in it that expands when heated up, the expansion moves the gauge needle via pressure.
Hello swadell, welcome to YT! If you are not familiar with tractor/automotive instrumentation what Jim means when he says “mechanical” in the case of the oil pressure gauge a tube connects the gauge to an electrical oil pressure tap on the engine. The gauge reads the pressure. The temperature gauge reads the engine temperature via a capillary tube and bulb that has captured fluid in it that expands when heated up, the expansion moves the gauge needle via pressure.
Both of your posts have been very helpful. Getting ready to pull it into the shop to start working on the gauges.
