offset1968
(originally posted in wrong forum)
Hello Everyone,
I've posted a few times regarding an old MF 150 my Dad and I have been running for the past year.
Overall it has been doing really well, especially in L1, only thing is you can walk faster than that 1st Low Gear
Some recent issues: Solenoid suddenly seemed to fail ... and having replaced ... seems to have happened again.
The first one that failed was OLD, I don't know if original, but it was OLD.
The wiring had already been entirely replaced when we purchased, we have replaced a few lines but in general it is wired in as simple a manner as possible.
We have one of those Amazon 'copied' factory manual that we purchased but the graphics are so poor the wiring diagram is useless. Plus again this one has nothing wired other than the motor .. no lights, no gauges, no safety switches.
First question: From the resistor block, we feed the coil a lower voltage as I understand to not burn up the points, but why then do we feed the coil directly from the "R" on the solenoid?
Won't this be a high voltage that would in fact burn the points?
Should "R" be fed into the other side of the resistor instead of directly to the coil since in this case I have the older points distributor?
Next question would be if this wiring diagram is correct ... or can this wiring be leading to this sudden issue of multiple solenoids suddenly dying?
This is exactly how our tractor is wired .. quick diagram I made:
Hello Everyone,
