Stan Coryell
I think I've gotten most of my throttle
linkage issues straightened out except for
one. I had to make a new Compensator
Spring Link from some dimensions I found
in another thread. See picture. The
problem is it seems too short. With the
cam adjusted to idle, the Compensator Link
locks past it's center. I'm pretty sure
making it about 3/8 longer will correct
this. I plan on re bending one hook of the
spring, it doesn't sit right in the eye of
the water outlit housing. It came from
JENSALES). By the way, the Govenor seems
to be working correctly with the
Compensator Link removed.
So my question is, when not running and
the throttle set to idle, should the
Compensator Spring have tension on it?
Thanks in advance,
Stan
Thanks in advance,
Stan
