rotorwing90
1965 MF 2135 with Continental Z134 with Shuttle Shift transmission: A once seized engine now has a hard stop after a 5-10 degree rotation.
1. My shop manual has not arrived as of yet so I seek the wisdom of a kind/generous soul or two.
2. In the process of unseizing the engine, a hard stop was felt after I achieved a 5-10 degree engine rotation. I did not force it beyond the hard stop.
3. Ive removed the head to see the condition of the cylinders and to see if there was a foreign object in one of the cylinders. Cylinder walls were scaly but not too bad in my opinion (Scotch-Brite is being used to remove the scale). No foreign object found in cylinders.
4. My thoughts at this point: the hard stop is not from the bottom end (crank, main & rod bearings, journals) since the engine rotates its 5-10 degrees with minimal effort. Im thinking something connected to the cam shaft: camshaft lifters, oil pump, governor, distributor gear
In anybodys opinion, am I overlooking something?
Thoughts? Suggestions?
Dennis in the Texas Panhandle
