MF 65 Oil Pressure
cmenard
Just purchased a 1962 MF 65 in great condition. I noticed that the oil pressure runs high for the first 30 minute of use then balances out. The previous owner replaced all fluids and said they may have added a little more oil than what its called for. Is this normal behavior for the oil pressure or should I drain a quart out of it.
Overfilling oil will not raise pressure.
Fill it to the dipstick level. If it's overfull, drain some out, don't guess.
What are you calling high, pegged gauge? Or still in the normal? If the gauge is pegging, there is a problem with the relief valve in the pump, or a faulty gauge.
It is normal for one to drop pressure as the oil warms.
If this is a gas engine, as long as there is some pressure at warm idle it is good. They are not known for having high oil pressure. General rule, 10 PSI per 1000 RPM is safe.
What most of us run is 15w-40 diesel oil. It will lessen the high cold readings, and give easier cold starts because it is multi grade.
It is a Perkins 203 diesel engine and the injection pump is brand new. When I start it the pressure pegs all the way to high and then goes to normal about 30 minutes after running it.
