MF35 transmission seals
Joeackley1
I have a1962 MF35 with multi power. Can I replace the transmission input shaft seals without removing the top cover. I know you can on one without the multi power.
You don't need to remove the top cover to change the transmission input shaft seals. That is done from the clutch housing area. Do you have a repair manual? You will need that.
Yes I do but I’m showing a thrust washer on the multi power that I’m not seeing on the regular transmission. Just want to make sure I don’t drop anything while just changing through the front.
