Mf65 foot throttle
Brodie94
Hi does anyone know where to find a foot throttle kit for a Massey 65 mk2 diesel . I can only find kits for the 35 and 135 and a few others, or is there a foot control for another tractor that will fit the 65? Have seen photos of the 65 with a foot throttle before (photo attached) . TIA
Tell you something I did that worked great. I hated that stomp-down clutch pedal on my MF-240-S, so I searched scrap yards until I found a MF-255, with what I thought would work as a press-forward clutch pedal. Removed the pedal all the linkage, and installed is on my MF. Had to invent some welding, get a brass sleeve made for a bushing, and had to farmer-ize things, but it works great.
You might search around scrap yards, depends on how handy you might be, but you might do something like that.
The foot pedal and mount and the slotted quadrant that allos the foot pedal to overide the hand setting would be the hard part.
If the 35 kit will bolt that far, the other stuff worse case you might have to do some fab work.
I looked a 245 that didn't have foot throttle and started to investigate adding it but ending up another tractor with foot throttle already there.
