Minneapolis Moline M602 starter
Hutchpatriot
Hello, new to the site. I have a starter on my M602 that is not engaging the flywheel. I have had the starter taken apart and repaired a minor starter drive problem but still no engagement. I flywheel looks fine. I notice about 1/4 inch of play, back and forth, in the drive when it is plunged to full extension. Any ideas? A new starter drive is not available and salvaged drives are not either (whole starters are available but for $500 with the core).
https://smithcoelectric.com/product...ve-12t-cw-for-delco-bosch-prestolite-starters
Link to source for starter drive.
Wow, thanks for the quick reply WO! However, that starter drive does not look like the drive in my Delco Remy 1113620. And I do not see my starter model referenced anywhere. Can I be sure that this unit will mesh with my starter and flywheel?
There is a phone number on that site. Give them a call. Often, new replacements do not look exactly like the originals. Just found that out on a Ford 6.9 diesel starter. The Mitsubishi replacement looks almost nothing like the original, but it works much better.
Thanks Skipper, I will do this on Monday!
Yes, that drive SHOULD fit your application and your Delco 1113620, but cross references are not always 100% correct, so check it out!
Below is a more extensive drive cross reference for a Delco 1113620 on an M602.
ACCUTEK KNIGHTC123
ACE3-272
ACE4-472
AES1043
AIMSO-0743
ARROW38-1069
BOSCH2-006-202-000
BUTEC852957
CARGO131766
CATERPILLAR4N4517
CATERPILLAR8S1541
DAF850363
DELCO REMY1921998
DELCO REMY1921999
DELCO REMY1932605
DELCO REMY1918886C
DIXIEC-115
DIXIEC-115P
LEECE NEVILLE71031
LEECE NEVILLE75249
LEECE NEVILLEM029075249
PRESTOLITE59-186
PRESTOLITEPD7A
PUROLATOR480116
PUROLATOR480410
PUROLATOR480480
PUROLATOR873052
RCP5015
RCP6015
RCP9015
WAI54-118
WAI54-118-1
WAI54-118-2
ZEN117
ZEN1.01.0117.0
ZEN1.01.117
